Тем много(сорян) но, что то не объяснил толком ничего.
EXP ETC не прошел,хотя раньше все было норм,докупил карту и что то пошло не так
Последние логи :
2021.12.21:23:04:55.992: main Phoenix Miner 5.8c Windows/msvc - Release build
2021.12.21:23:04:55.992: main Cmd line: -coin ubq -pool ubq.kryptex.network:7000 -wal 0x510aec7f266557b7de753231820571b13eb31b57/v2a3a92269 -pass x -cdmport 127.0.0.1:12000 -rmode 0 -logfile 1640117092_ubq_12000_log.txt -gpus 1,2 -rxboost 1
2021.12.21:23:04:55.992: main No CUDA driver found
2021.12.21:23:04:56.556: main OpenCL driver version: 21.9-10.x
2021.12.21:23:04:56.570: main Available GPUs for mining:
2021.12.21:23:04:56.570: main GPU1: Radeon RX 590 Series (pcie 5), OpenCL 2.0, 8 GB VRAM, 36 CUs
2021.12.21:23:04:56.570: main GPU2: AMD Radeon RX 6700 XT (pcie 11), OpenCL 2.0, 12 GB VRAM, 40 CUs
2021.12.21:23:04:56.570: main ADL library initialized
2021.12.21:23:04:56.927: main Eth: the pool list contains 1 pool (1 from command-line)
2021.12.21:23:04:56.927: main Eth: primary pool: ubq.kryptex.network:7000
2021.12.21:23:04:56.927: main Starting GPU mining
2021.12.21:23:04:56.927: main Matched GPU1 to ADL adapter index 0 (method 1)
2021.12.21:23:04:56.940: main GPU1: AMD driver 21.10.2
2021.12.21:23:04:56.940: main GPU1: Created ADL monitor for adapter 0; overdrive version: 7 (7)
2021.12.21:23:04:56.940: main GPU1: using AMD driver ver 21.10.2
2021.12.21:23:04:56.940: main Matched GPU2 to ADL adapter index 7 (method 1)
2021.12.21:23:04:56.953: main GPU2: AMD driver 21.10.2
2021.12.21:23:04:56.953: main GPU2: Created ADL monitor for adapter 7; overdrive version: 8 (8)
2021.12.21:23:04:56.953: main GPU2: using AMD driver ver 21.10.2
2021.12.21:23:04:56.977: hwmc GPU2: unable to set straps - unsupported GPU
2021.12.21:23:04:57.101: wdog Starting watchdog thread
2021.12.21:23:04:57.101: main Eth: Connecting to ethash pool ubq.kryptex.network:7000 (proto: EthProxy)
2021.12.21:23:04:57.101: main GPU1: 35C 24% 28W, GPU2: 44C 0% 8W
GPUs power: 36.4 W
2021.12.21:23:04:57.164: eths Eth: Connected to ethash pool ubq.kryptex.network:7000 (136.244.81.247)
2021.12.21:23:04:57.165: eths Eth: Send: {“id”:1,“jsonrpc”:“2.0”,“method”:“eth_submitLogin”,“worker”:“eth1.0”,“params”:[“0x510aec7f266557b7de753231820571b13eb31b57/v2a3a92269”,“x”]}
GPU2 Невозможно подготовить ядра: Обнаружена критическая ошибка. Перезагрузка а GPU2: это AMD Radeon RX 6700 XT - Эту карту в основной слот , а 590 в райзер втыкайте или в другой слот но не в первый . AMD driver 21.10.2 -это последние, а для 590 они не подходят , поэтому возможен конфликт между картами - ставьте 21.2.3 драйвер…ну или не самый последний , а лучше посмотреть последний который 590 поддерживает и есть ли такой же драйвер для 6700 на сайте амд . Это так на первый взгляд … скорей всего режим вычислений не включён на второй карте - остальное специалисты скажут .
Так 6700 и так в основном стоит на PcI х16 -4.0 а 590 на PCI х1-3.0
на 590 включен режим вычисления,на 6700 нету в настройках)
Да и 590 капала месяц без проблем,а вот с установкой второй карты проблемы в фениксе.
clCreateKernel (-46) обычно означает либо кривой драйвер, либо кривой райзер. Но второй вариант отпадает, если карта в материнке. Значит, надо пробовать драйвера постарее. Я все еще работаю на 20.5.1.
Ситуация такова на сегодняшний день,если не смотреть на вчерашний) На 20.5.1. не увидел 6700 и отказывался работать хз с чем связано,на 21.2.3. так же конфликтует,если убирать 6700 то нормально проходит проверку и копает,как и на более новых дравах.
Получается 6700 не хочет работать вместе с 590.Возможно у кого нибудь стоят такие карты и не возникает трения,хотелось бы понять решения ситуации.
Мать b550 aorus elite v2
А по отдельности они копают ? проверку проходят ? сначала 6700 проверь , сохрани результаты файла benchmark.json , , потом 590 и сохрани тоже файл benchmark.json и из двух файлов отредактируй через блокнот, сделай один и замени файл в криптексе . У меня так же было с 588 и 390 картами - вместе проверку не проходили , а по отдельности копали …Открыть этот путь в проводнике Windows: C: \Users\ Имя_Пользователя\AppData\Roaming\Kryptex Затем откройте файл benchmark.json через блокнот и сохраните на рабочий стол например .
2021.12.22:18:03:53.406: GPU1 GPU1: Failed to compile program: clBuildProgram (-11)
2021.12.22:18:03:53.406: GPU1 GPU1: Free VRAM: 11.922 GB; used: 0.063 GB
2021.12.22:18:03:53.406: GPU1 GPU1: Allocating DAG (2.86 GB); good for epoch up to #238
2021.12.22:18:03:53.419: GPU1 GPU1: Generating DAG for epoch #236
2021.12.22:18:03:55.158: GPU1 GPU1: DAG 64%
2021.12.22:18:03:55.501: main Eth speed: 0.000 MH/s, shares: 0/0/0, time: 0:00
2021.12.22:18:03:56.177: GPU1 GPU1: DAG generated in 2.8 s (1056.2 MB/s)
2021.12.22:18:03:56.178: GPU1 GPU1: Unable to prepare kernels: clCreateKernel (-46)
2021.12.22:18:03:56.178: wdog Fatal error detected. Restarting.
это на 6700 по одиночке тоже не проходит,на разных разъемах.
А 590 проходит.
"Не удалось скомпилировать программу: clBuildProgram " Так у него и на старых дровах не проходила проверку , такое впечатление что там вообще дров нету для этой карты - не плохо бы посмотреть что в “диспетчере устройств” эта карта показывает .
“Диспетчер устройств” гляньте , если там жёлтый треугольник на ней , то дрова частично только работают - и там же обновите в любом случае и повторно проверку попробуйте пройти только для этой карты отдельно , если не пройдёт - то придётся ждать обновления феникса , или старые дрова поставить и попробовать на них пройти , смысл в том что бы заставить сначала эту карту работать, а потом уже подключать 590 . А если брали " с рук " эту карту , то возможно что она уже перешитая под майнинг , и просто требуется патч поставить .
В диспетчере все норм,а по дровам я же ставил и удалял штук 7 разных версий,тем более не стоковые настройки,не было бы дров не смог бы управлять через По радеон.
Вообще хорошая привычка - проходить проверку оборудования на стоковых настройках.
Если карты проходят на стоке, а с разгоном не работают - причина разгон.
Если ПК вырубается наглухо - не хватает питания
Если не проходит проверку на стоке - антивирус, маленький файл подкачки, проблема с дровами, проблема с райзером, не настроен BIOS материнской платы (включить Above 4G Decoding, перевести PCI-E в режим Gen2, или Gen1)
