Манипуляции проведены. После установки R9 обратно, Kryptex отправил Vega64 в неизведанные.
Ещё раз провести проверку?
Нет, скиньте текущий файл бенчмарка, посмотрю.
"benchmark": {
"version": 48,
"result": [
"device": {
"type": "GPU",
"vendor": "AMD",
"index": 0,
"pciId": "08:00.0",
"name": "AMD Radeon RX Vega"
"tests": [
"configuration": {
"miner": "TEAMRED",
"coin": "ETH"
"hashrate": 34.5
"configuration": {
"miner": "NBMINER",
"coin": "ETH"
"hashrate": 38.01
"configuration": {
"miner": "TEAMRED",
"coin": "ETC"
"hashrate": 29.31
"configuration": {
"miner": "NBMINER",
"coin": "ETC"
"hashrate": 34.2
"configuration": {
"miner": "TEAMRED",
"coin": "RVN"
"hashrate": 21.17
"configuration": {
"miner": "NBMINER",
"coin": "RVN"
"hashrate": 20.57
"configuration": {
"miner": "PHOENIX_MINER",
"coin": "UBQ"
"hashrate": 34.76
"configuration": {
"miner": "TEAMRED",
"coin": "ERG"
"hashrate": 122.48
"device": {
"type": "CPU",
"name": "AMD Ryzen 9 3900X 12-Core Processor "
"tests": [
"configuration": {
"miner": "XMRIG",
"coin": "XMR"
"hashrate": 10881.76
Попробуйте это подставить:
"benchmark": {
"version": 48,
"result": [
"device": {
"type": "GPU",
"vendor": "AMD",
"index": 0,
"pciId": "08:00.0",
"tests": [
"configuration": {
"miner": "TEAMRED",
"coin": "ETH"
"hashrate": 34.5
"configuration": {
"miner": "NBMINER",
"coin": "ETH"
"hashrate": 38.01
"configuration": {
"miner": "TEAMRED",
"coin": "ETC"
"hashrate": 29.31
"configuration": {
"miner": "NBMINER",
"coin": "ETC"
"hashrate": 34.2
"configuration": {
"miner": "TEAMRED",
"coin": "RVN"
"hashrate": 21.17
"configuration": {
"miner": "NBMINER",
"coin": "RVN"
"hashrate": 20.57
"configuration": {
"coin": "UBQ"
"hashrate": 34.76
"configuration": {
"miner": "TEAMRED",
"coin": "ERG"
"hashrate": 122.48
"device": {
"type": "GPU",
"vendor": "AMD",
"index": 1,
"pciId": "06:00.0",
"name": "AMD ASUS R9 280 Series"
"tests": [
"configuration": {
"coin": "UBQ"
"hashrate": 37.82
"device": {
"type": "CPU",
"tests": [
"configuration": {
"miner": "XMRIG",
"coin": "XMR"
Без изменений. Vega серая.
Вы же меняя файл или данные в файле, полностью закрываете программу?
Если программа активна - никакого эффекта это не окажет.
Естественно. Файл же %appdata%\Roaming\Kryptex\becnmark.json ?
После запуска записи сохраняются.
После перестановки карт винда по-новому их прописывает и присваивает им DeviceID
(скорее всего, может и нет. Так могу только гадать)
Со 95% совместимостью можно наладить только LinuxOS (Hive\Rave) и то будут свои приколы.
В данном, конкретном случае, вижу ещё одно решение вопроса.
Если карта R9 нужна только как вывод изображения, и больше ничего - поставить стандартный базовый видеодрайвер Microsoft вместо AMD.
Спасибо. Работающую видеокарту в мусорку. Всем спасибо.
Как закрыть тему?
